huntch3 Posted September 6, 2009 Share Posted September 6, 2009 Hi everyone I'm trying to save a render as an AI (adobe illustrator file) so that it saves the lines as vectors only....but when i go to choose the file type to save as, ever possible file type except ai shows up in the list...I have illiustrator...what am I missing??! thanks Link to comment Share on other sites More sharing options...
SandmanNinja Posted September 6, 2009 Share Posted September 6, 2009 I don't think 3ds can output it's renders as vectors. I know I use to use a programmed called "Corel Draw" years ago and it had a CorelTrace that did a pretty good job. Check AI - there must be a similar tool in there. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted September 6, 2009 Share Posted September 6, 2009 I have a friend that uses Illustrate!. I was fairly impressed with the vector lines it was putting out, and will purchase the next time I need this. There is a demo version... http://www.davidgould.com/Illustrate/IllustrateForMax/Illustrate53.htm ....Technically, if your using MR, you can render directly to a postscript file when using the contour shaders. The PS file can be opened in Illustrator, but the data is pretty much junk. Link to comment Share on other sites More sharing options...
Paul Twyman Posted September 6, 2009 Share Posted September 6, 2009 I know I use to use a programmed called "Corel Draw" years ago and it had a CorelTrace that did a pretty good job. Check AI - there must be a similar tool in there. Yeah there is Live Trace and Live Paint under the Object Menu which does this. You will probbaly have to play around with the settings to get anything close to decent though. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted September 13, 2009 Share Posted September 13, 2009 Agree with Travis on both "will get Illustrate" (even though it seems to have halted development) and that the MR EPS output is essentially useless. Pencil looks good too. I hate being poor ;-). Link to comment Share on other sites More sharing options...
