3dsmax and vray help
some
Hi guys ,
i thought of rendering a animation of an Bakery interior.As i calculated maps of IRmap and lightcache map of 400 frames. The problem is here when i render the image in my system it renders correctly. When i render that same image in another system its not rendering correctly means it render black as you can see the images below for refernce. I have installed autodesk3dsmax2009 and vray 1.50 sp2. I am not rendering in any network nor not using any backburner and no internet in that system nothing. But the problem still . I tried in my friend system also the same problem. And i have copied each and every file like bmp jpg ies irmap lightcache map etc. I have marked the area of problem. Pls persists:);)
Just a few ideas. Might be way off the mark but worth suggesting
1. Can the 2nd computer see the irmap you calculated? As in is it in a network location or on a local computer
2. like the others say, looks like it could also be a gamma issue (customise, preferences, Gamma and LUT)
If "hgf hfhgf" alias "some" from "hgfhgf" said that he/she copied the imap file to the other computer, then it must be read correctly.
Color mapping are other settings are not suposed to change from one computer to the other.. then it is gamma...
Kippu: the flag is from one of the first countries in the list... "hgf hfhgf" was in a rush, no doubt.
Tanx for all ur help guys
As i tried all ur ways. Their is no gamma issue nor any color map changing its all perfect and i am using same version of vray in both the system. And one thing i observed is only this file is a prob for me rest of them rendering successfully.And also i have given the path for all maps and textures.
Edited by some
