borisram Posted September 10, 2009 Share Posted September 10, 2009 Hi everybody I've noticed that vray 1.5 sp2 is slower than the past versions, but it gets worst when i try to render animations, so I tried to figure it out by making some test and I discovered that the render time for an specific frame increases every time I render it. Specificaly.. the first time, just after the scene has been opened, it takes 23 secs to render. When I try to render the same frame with the same settings again, it takes about 35 secs to render. And whe i hit render again, it takes 58 secs... the sixth time, takes about 2 minutes rendering the same frame. Does anybody have an idea of what is happening with my vray... or is any kind of known problem???? Please help!!! I use 3ds max 2009, windows xp 32 and 64 bit Sorry about my english! Link to comment Share on other sites More sharing options...
jkrock3d Posted September 11, 2009 Share Posted September 11, 2009 Hmm... sounds interesting... restart your system everytime u render lets see the timeline then Link to comment Share on other sites More sharing options...
Tommy L Posted September 11, 2009 Share Posted September 11, 2009 Is it scene specific? Or does it happen on every scene? Link to comment Share on other sites More sharing options...
braddewald Posted September 11, 2009 Share Posted September 11, 2009 Sounds like it is probably an issue with your RAM. I cannot speak for sure on the matter, but I agree with Jkrock3d: restart your system after each render and check the timeline then. If it seems to be the same render time after restarts, I would start thinking about some kind of RAM-cleaning software. Link to comment Share on other sites More sharing options...
borisram Posted September 11, 2009 Author Share Posted September 11, 2009 SOLVED!!!... it was a temperature problem. My q6600 was reaching 80C degrees. So i had to remove some dust on the cooler and now is working better than ever... Thanks for your answers!! Link to comment Share on other sites More sharing options...
SunGlare Posted September 11, 2009 Share Posted September 11, 2009 Hah. I wish all problems could end this way. "there is too much noise in my render!" - dust of your hard drive and your good to go! That was a good one.Thanks Link to comment Share on other sites More sharing options...
