craigball Posted September 10, 2009 Share Posted September 10, 2009 I have been having problems with matching colours using RGB eg i have a logo using R 0 G 0.34 B 0 when i input that in the material editor its the totally different colour. thanks Link to comment Share on other sites More sharing options...
erickdt Posted September 10, 2009 Share Posted September 10, 2009 Are you using gamma correction via. customize>preferences>gamma and LUT? If so, that could be your problem if it's not set to affect input and output. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted September 10, 2009 Share Posted September 10, 2009 I have been having problems with matching colours using RGB eg i have a logo using R 0 G 0.34 B 0 when i input that in the material editor its the totally different colour. thanks Off hand, I am guessing it is a gamma problem. You can try a quick correction by placing a Color Correct shader in the diffuse slot, then assigning the color green color to the map area as I have shown in the attachment. The key in either .454, or 2.2 depending on which direction the gamma is off, and what gamma you are using. Hopefully that help. Link to comment Share on other sites More sharing options...
craigball Posted September 10, 2009 Author Share Posted September 10, 2009 its not the gamma, at work we got a logo with the color and the RGB numbers and when i inputed the same figurs in each of the R G B slots the colour was miles diffrent eg was ment to be green and it comes out red? but in PS it works every time ? Link to comment Share on other sites More sharing options...
thnkr Posted September 10, 2009 Share Posted September 10, 2009 If it works in PS then you're likely working in a color space. Maya doesn't do this. RGB values in PS are not absolute; the same color has different values in sRGB and Adobe RGB spaces. For compatibility with Maya, try using the Monitor RGB profile or turn Color Management off. You can do this in Edit > Color Settings. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted September 10, 2009 Share Posted September 10, 2009 Maybe try creating a color swatch in PS, and then applying it as a bitmap in the diffuse channel of your material. Link to comment Share on other sites More sharing options...
craigball Posted September 11, 2009 Author Share Posted September 11, 2009 Maybe try creating a color swatch in PS, and then applying it as a bitmap in the diffuse channel of your material. thats what i have been doing. i just think its the wrong way around it? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted September 11, 2009 Share Posted September 11, 2009 This is what I get when I put the above colors in Max/MR... Link to comment Share on other sites More sharing options...
