sipherlucian Posted September 10, 2009 Share Posted September 10, 2009 hi ive never really had this problem with vray before but this scene that on has a lot of noise in it, the scene is supposed to be quite dark with volume lights, its not finished yet im just working on it. attached is the latest render and settings in vray, vray 1.5 sp2 ive tried inscreasing the settings but they made absolutely no difference please help im really stuck at the moment, thanks in advance Link to comment Share on other sites More sharing options...
Devin Johnston Posted September 10, 2009 Share Posted September 10, 2009 Try turning up the samples in your lights. Link to comment Share on other sites More sharing options...
BrianKitts Posted September 10, 2009 Share Posted September 10, 2009 whats your noise threshold set to? Link to comment Share on other sites More sharing options...
sipherlucian Posted September 11, 2009 Author Share Posted September 11, 2009 these are the rest of my settings attached. i played around with these last night and got a clearer result but the render time is huge! the main area im concerned about is the opening in the ceiling thats the worst affected, the main light source for the room comes from there, the characters have their own lighting. they came out a better quality. critisism is welcome by the way, its not finished obviously, theres no texturing for the room yet but all the same tips and comments are welcome! thanks devin ill give that a go Link to comment Share on other sites More sharing options...
DanGrover Posted September 11, 2009 Share Posted September 11, 2009 What sort of light is it up there? Is it a big plane that's shooting light downwards? If so, it's probably using up a lotttt of samples making them shadows, especially with the occluding objects so close to it (ie the central bit of the ceiling where no light is coming from). What might actually be quicker (though it'd be worth testing of course) is instead of having a plane light up there (again, assuming you do), try having a piece of geometry that fits perfectly in the space where the light is (ie, a donut-shaped plane) and apply a Vray LightMtrl to it? That might cut down on the render times, but I'm not 100% sure by any means. As for the scene, I'd say that the robot is screaming out for some reflections! I know it's a cartoony look (and it looks fantastic), but I really think some nice reflections would look lovely on it. Link to comment Share on other sites More sharing options...
sipherlucian Posted September 11, 2009 Author Share Posted September 11, 2009 Hey dan thanks for the tip ill give it a try! the robot is reflective, a bit but ive textured it to be worn down, i think in this dark room you cant really appreciate the reflections on him, so i may on them in post. there is one rectangle light coming from the ceiling and 1 coming from a small space in the ground as ive marked on the attachment, also in the ceiling is a direct light with volume effect applied to it. the settings on both vray lights are as follows... subdivs: 8 shadowbias: 0.02 i changed them to 50 and 0.002 and noticed an increase in quality but not that much i think these new settings might be too high??? Link to comment Share on other sites More sharing options...
braddewald Posted September 11, 2009 Share Posted September 11, 2009 Try going to your render settings dialogue and under the settings tab go down to light settings, select all of your lights and change their diffuse subdivisions to something really high, like 500 or 1000. This works for me usually, but only in some situations. Link to comment Share on other sites More sharing options...
