msanandkumar Posted September 15, 2009 Share Posted September 15, 2009 Hi this is Anand i have a scene(exterior animation), i have calculated irradiance map and light cache in a right way, but while rendering irradiance map is recalculated once again for every frame, i dont know why its acting like this.......... even i rechecked all settings and they are correct, if any one can suggest something to solve this it will be of great help, thanks in advance. Link to comment Share on other sites More sharing options...
tayrona Posted September 15, 2009 Share Posted September 15, 2009 In your scene, there are materiales using interpolations. you should uncheck this option to avoid the "aditional passes". Link to comment Share on other sites More sharing options...
msanandkumar Posted September 16, 2009 Author Share Posted September 16, 2009 Hi Tayrona........ Thanks for your response...... i will do that, but the problem is now i have to search thousands of materials in the scene to check if that is on or not, thank you. Will reply you back after i do this. Thanks Link to comment Share on other sites More sharing options...
msanandkumar Posted September 16, 2009 Author Share Posted September 16, 2009 Hi Tayrona....... It took me 2 hours to search all materials , found 2 interpolations, but after i finished with that, i put render again it is showing same thing,,,,,,,,,,,,,,,,,,,,, i mean once again it is calculating the Irradiance map:eek:. Do you think i missed some interpolation checks:confused:? or this is caused by something else? Please suggest..... Link to comment Share on other sites More sharing options...
kao bebird Posted September 16, 2009 Share Posted September 16, 2009 Do you set the irradiance map mode ? Usually, the the irradiance map mode is set to Single frame by default. Set to Incremental add to current map for multiple views or fly through. And set to Animation (prepass) &(rendering) for animation. May my answer help you ? Link to comment Share on other sites More sharing options...
msanandkumar Posted September 16, 2009 Author Share Posted September 16, 2009 Hi Kao thanks for your reply........... I actually calculated irradiance map using incremental add to current map, and now i am using it using from file option........ i think this is correct. As i am not doing any dynamic animation in the walkthroug. But when it renders, it once again recalculates irradiance map........... so can any tell me how to solve this problem:confused: Link to comment Share on other sites More sharing options...
tayrona Posted September 16, 2009 Share Posted September 16, 2009 but the problem is now i have to search thousands of materials in the scene to check if that is on or not, There is an script to change interpolations globally (and other v-ray settings): "V-ray Automator"... it is free and easy to install and use. Link to comment Share on other sites More sharing options...
msanandkumar Posted September 16, 2009 Author Share Posted September 16, 2009 Hi Tayrona, Problem is solved........... thank you very much Tayrona. That is a great script...... and your guess was 100% correct. Thanks once again, it just saved me..... Link to comment Share on other sites More sharing options...
