Cesar R Posted May 26, 2003 Share Posted May 26, 2003 When I am in the modeler, all I see is EPSF_Loader. I can export to 3DS from archicad, but how I get it into Lightwave? Link to comment Share on other sites More sharing options...
dwright Posted May 26, 2003 Share Posted May 26, 2003 Hi there.. Simply load it into modeler as any object, make sure your loading extension filter is set up to *.* all files, do not load into Layout (lw) it will not work. Link to comment Share on other sites More sharing options...
Cesar R Posted June 9, 2003 Author Share Posted June 9, 2003 Whenever I import a 3ds file or any file into LW it loads everyting into one single "unamed" layer. then I have to break everythign into defferent pieces, Ie. doors windows and walls. Is there a way to import into its apropiate layers? is the same with autocad? Link to comment Share on other sites More sharing options...
dwright Posted June 10, 2003 Share Posted June 10, 2003 no via LW. Using polytrans or similar type of app. Sorry! David Link to comment Share on other sites More sharing options...
Andronikos Posted September 20, 2003 Share Posted September 20, 2003 I am so stupid or what? I am trying to import a file from Archicad to Lightwave but no luck! ...can someone write step by step what i should do? should I export it from archicad to .3ds? sorry guys, I know that what I am asking is silly but I need some directions here... Link to comment Share on other sites More sharing options...
dwright Posted September 20, 2003 Share Posted September 20, 2003 yes via 3ds. LW does not read archicad files directly, only 3ds/dxf/obj (wavefront obj). export your file as 3ds and that should do it. David Link to comment Share on other sites More sharing options...
Andronikos Posted September 28, 2003 Share Posted September 28, 2003 do I have to import the .3ds file using the modeler7 or the lightwave7? ...still I can not find out how to do it... sorry... Link to comment Share on other sites More sharing options...
Allen Posted September 30, 2003 Share Posted September 30, 2003 Use modeler. Open and for "types of files" - select - 'All Files' in the explorer window - otherwise you'll only see the lwo files. I use this option all the time to get from AutoCAD to LW - Works great. Link to comment Share on other sites More sharing options...
