chow choppe Posted September 16, 2009 Share Posted September 16, 2009 hi everyone i have some mocap files, and 3d models from AXYZ. i dont know how to make my 3d models use these mocap data so that my 3dmodel can move using the mocap data. i know how to make a biped and then load mocap data into it but how can i put it to my 3d model from AXYZ. do i need t pose models for this? and then what? sorry i dont have much knowledge about character studio. but want to use these for my walkthrough exteriors please hlep. any tutorial? thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted September 16, 2009 Share Posted September 16, 2009 You need the rigged models, not just the 3d models (they sell both) If you have the rigged models, there is a full how-to instruction guide that comes with the product. Link to comment Share on other sites More sharing options...
wasteland giant Posted September 16, 2009 Share Posted September 16, 2009 there is a full how-to instruction guide that comes with the product. Link to comment Share on other sites More sharing options...
SandmanNinja Posted September 17, 2009 Share Posted September 17, 2009 RTM or RTFM? lol Perhaps a call to tech support would help. When they tell you the answer, please share it. It'll be great to hear it. Link to comment Share on other sites More sharing options...
chow choppe Posted September 23, 2009 Author Share Posted September 23, 2009 i read the guide but apparently the mocap data is in .bvh format and the guide shows loading a .bip data. whe i try to load open a mocap file it doesnt show me file type option for selecting bvh files thanks Link to comment Share on other sites More sharing options...
Dave Buckley Posted September 23, 2009 Share Posted September 23, 2009 do a search for free mocap data on the web, there ar thousands of free clips, also don't forget the free samples that ship with max. if possible, then use motionbuilder, its designed for exactly what you want and is really easy to use. if not then here's a basic workflow. with your rigged model you need to press h to open your select by name dialog, then you wanna select te base object of the biped (ending Bip01 in most cases) with this selected only, go to your motion tab of the command panel. from here you should be able to enter motion flow mode (it's next to the t-pose icon and the footsteps icon) when in motion flow, you need to click the show graph icon. in here you can load various .bip files using the load multiple clips icon when your clips are loaded in, you need to click the define script icon on the command panel. this then allows you to select the clips (in your graph) in the order that you want them to be applied to your character. this will then generate footsteps according to the bip files. press play. there may be some discrepency in what i have just outlined (telling you from memory at the minute) but this should give you the basic idea hope it helps Link to comment Share on other sites More sharing options...
Stephen Thomas Posted September 23, 2009 Share Posted September 23, 2009 Max can also convert .BVH files, though I've had trouble doing it in the past. Select the base object of your biped then under the motion tab go to the 'motion capture' rollout and you will find a 'batch file conversion' button. This should allow you to convert .BVH and .CSM files to .BIP. Link to comment Share on other sites More sharing options...
chow choppe Posted September 23, 2009 Author Share Posted September 23, 2009 Max can also convert .BVH files, though I've had trouble doing it in the past. Select the base object of your biped then under the motion tab go to the 'motion capture' rollout and you will find a 'batch file conversion' button. This should allow you to convert .BVH and .CSM files to .BIP. thanks man. i was directly able to load the bvh files from motion capture tab but when i try to load the bvh file my character blows up and all mesh gets distorted( see image below) i tried following the guide provided by axyz but still getting that problem. the guide is here what is wrong? Link to comment Share on other sites More sharing options...
Nic H Posted September 23, 2009 Share Posted September 23, 2009 have you scaled the character at all? or done anything to do with changing units? Link to comment Share on other sites More sharing options...
chow choppe Posted September 23, 2009 Author Share Posted September 23, 2009 yes i did read this guide http://www.the3rddimension.in/guide.pdf My character was using a physique modifier as per pdf. What i did was: i opened max Changed units to meters Merged the character Selected the biped and went to motion capture tab in motion panel and loaded BVH files and that image is what i got thanks Link to comment Share on other sites More sharing options...
arkav Posted September 30, 2009 Share Posted September 30, 2009 Hello 3dsmaxed did you solve your problem? i have the same problem man, i hope somebody help me. Link to comment Share on other sites More sharing options...
WL500GP Posted September 30, 2009 Share Posted September 30, 2009 i'd try and save the skin data(physique or whatever it's using), perhaps also save the biped configuration(number of toes etc etc), then detatch the mesh from the biped(delete the "skin" modifier in other words), scale the mesh to your needs, apply a reset xform to it afterwards, scale up your biped so it fits your mesh, reapply the physique modifier, load your saved physique/skin data if that doesn't work, i'd reskin it with the skin modifier instead of the physique(physique has always had a fair amount of suckage to it imho...) Cheers, k. Link to comment Share on other sites More sharing options...
