make one object animation available in only 1 camera
chow choppe
Hi
i am working on 2 cameras animation of the same are.
in one camera i want the door to be animated but in the other camera angle i dont want that door to animate. Also i dont want to use separate save as scenes for 2 cameras.
is there any way to do it in the same scene?
can i turn off objects animation for a specific camera
thanks
Use the timeline in your advantage. Let's say that your first path has 300 frames and the second 250. Have the first path rendering from frame 0 to 299, then make the second path start from 300 to 249. And as said before you have 2 groups for the doors that you can play with. You can either do the visibility thing but that sometimes creates problems when rendering with vray or just animate the position of the groups. Have one moved on the Z axis outside of the field of view while the other is in the proper location and switch for the other path.
hi
figured it out. It was very easy
similar to what anton said but i did with a single door.
i made animations from say 1-200(first shot ) and 210 to 400(second shot)
in first shot door opens and stay opened till frame 200
and at 205 or i use set key to close the door again and
Voila!
thanks for the info guys
