vtapesh Posted September 21, 2009 Share Posted September 21, 2009 I am working on walkthro for this project but i am not happy with lighting and also it is taking 24 min to render a single frame. I am using vray sky with direct light + gamma Please help me. Thanks Link to comment Share on other sites More sharing options...
Stephen Thomas Posted September 21, 2009 Share Posted September 21, 2009 I think the lighting is looking good actually! If you want to drop your render times there are a number of things you could try. Firstly drop the Hsph subdivisions in your irradiance map settings down from 50 to 30, secondly try light cache rather than brute force, although with only 1 bounce the brute force method may well be quicker in this case. Also I would look at your materials, especially the trees, and look for any glossy refractions with high subdivisions that may be causing problems. I assume you're already using vray proxies for your vegetation. Link to comment Share on other sites More sharing options...
puciorek Posted September 21, 2009 Share Posted September 21, 2009 change Brute Force to Lightcache in your secondary bounce Link to comment Share on other sites More sharing options...
vtapesh Posted September 22, 2009 Author Share Posted September 22, 2009 thanks for your valuable support, i will try this. but there is no glossy reflection, still i am finding it heavy. thanks Tapesh Link to comment Share on other sites More sharing options...
