HDRI Vray image issue
monkeyman905
It's probably worth dropping a vray plane into your scene just to gauge how off your horizon really is first. Make sure your ground level is at zero on the z axis too, as a 50-50 split in your HDRI should be the correct place for your horizon. If you really want to change it you could stretch the top half down slightly in photoshop. Or by adjust the vertical rotation, though that may have the effect of raising the horizon in your reflections.
Hi, yea i had the scene at zero on the Z axis. Ive played around with the vertical rotation which has sorted this so thank you. But now when i render in perspective viewport everything is fine, but when i go to render with the vray camera they is no HDRI background at all it is just black! i have placed the HDRI image in the eniroment slot and i also have vray sun in the scene. Is they an option i need to tick or something i have to set with the vray camera??
I know why im having issues with Vray camera its to do with the setting so if i have my normal camera settings with the F-number at 8 then my models look fine with the light ect but i cant view the hdri sky. So i change the F-number to 1 and i can see the hdri sky but then the model is over exposed to the light. Even if i play with the shutter speed nd film this does not change. The f-number is just to low. Is they a solution to this??
Can you please elaborate that?
Thank you
Hi guys, sadly unchecking affect background doesnt do anything nither does uping the multplier ing the material settings!!
After playinga round with the camera i have something usable using these settings:
F-number 10.0
shutter speed 10.0
film speed 1250.0
Sun settings
Intensity multipler 0.01
size multiplier 1.0
are these a bit extream?? i was thinging they would have been a easier way like just uping the multiplier!!
Thats kinda what i was thinking it was first thing i was told never change the sun multiplier. Their is an issue in what i have done anyway the HDRI is not been reflected in the glass at all. After some research ive read that i should change the HDRI multiplier x1000 - x1500. Ive only been doing it x20. So ill set the scene up again when the HDRI was to dark and try these higher multipliers and see if that works plus i hope this will then show the reflections in the glass. Is they an option i should tick in the glass material??
Sorry for all the questions first time ive used HDRI
