VirtualCAD Posted August 14, 2003 Share Posted August 14, 2003 Hi any one I had try o import a DXf file into LW but everytime this come like in 2D only my 3D model dosen´t show up proprpely I´m using the modeler to do that. Can you tell me how to import a DX file or if sould I use another way to make it. Thaks a lot Graicas Ronaldo Link to comment Share on other sites More sharing options...
ingo Posted August 14, 2003 Share Posted August 14, 2003 Hi Ronaldo, i think its better to use another way, where do you get your DXF from ? I would choose 3DS instead, or obj file format. HTH Link to comment Share on other sites More sharing options...
VirtualCAD Posted August 14, 2003 Author Share Posted August 14, 2003 Ok I will try that. I export my DWG file to a DXF file and than I try import it to LW. So, If see better use other way please send me how can I do it. Thanks man Ronaldo Link to comment Share on other sites More sharing options...
dwright Posted August 14, 2003 Share Posted August 14, 2003 You have to use DXF R13 or lower to make it work, I think is R13. Newtek has not updated these importers for a long time. Exporting 3ds from ACAD also works. cheers Link to comment Share on other sites More sharing options...
VirtualCAD Posted August 19, 2003 Author Share Posted August 19, 2003 Ok people it realy works Thank you every one. But now I got a little problem, the file become into a unic layer and it like my file is to heave to run in my computer. Should I take any previous care before load in my 3DS file into LW? But thanks anyway for the help. Ronaldo Link to comment Share on other sites More sharing options...
