Max failed to start
Devin Johnston
I had this happen at home with vista, can't say as i ever figured out wtf happened though as i was only using the 30day demo to patch up a little work and haven't had to use it since.
Has there been any recent windows updates?
Does anything show up in the event log when you start max... start, run, compmgmt.msc, Event Viewer, check the Application log and the System log.. doesn't ususally get you useful information, but it can net you something to search towards online.
Try this if you are not already doing this...
Open "InstallSettings.ini" in the root 3dsMax directory. Then change the useUserProfiles=1 to useUserProfiles=0. Caution though, this will make 3dsMax use only the 3dsMax directory, and not the My Documents directory.
This is similar to deleting the 3dsmax.ini, but typically deleting that file fixes a lot of problems, though it resets your settings.
[Least User Privilege]
useUserProfiles=0
installedBuild=1
