how to find missing maps in distributed rendering
max.m
hi there, although i use vray for a couple of years it`s the first time i use distributed rendering. i got everything working, but 2 things are left that make me struggle a bit.
i organized all scenes with unc paths since i use dr, but when i want to use older scenes with some materials without unc paths the render server quits as it doesn`t find the maps.
question: is there a way to find out which objects or materials embed the missing maps?
question2: i use dr between 2 x64 workstations. i also tried to participate a 32bit pc, but this one always quits.
is this because the 64-bit 32-bit mix?
xp64, max9, vray sp3a
thx
Hey,
Probably easier to strip the paths of the bitmaps (if that's what it's missing?) through the asset tracker (file>asset track..) then relink them through this nifty plugin... http://www.scriptspot.com/3ds-max/relink-bitmaps which is super fast and reliable.
Distributed rendering should have all paths exactly the same; relinking to your new server as above should fix this.
Personally I wouldn't try and mix 32 and 64 bit for the same job. Send all your masks or something less RAM intensive to the old 32 bit, then eventually ditch them.
