ezzor Posted September 27, 2009 Share Posted September 27, 2009 (edited) Hello, i need help with my 'Logo' Textures I want the cylinder(8 parts) texture to look like the logo to the left BTW. The Global Dynamic text is Not going to be attached to the circel only the Logo i want the cylinder in 8 parts becuse it's going to be a animated lock function Thx Edited September 27, 2009 by ezzor info missing Link to comment Share on other sites More sharing options...
Horhe Posted September 27, 2009 Share Posted September 27, 2009 Change the UW mapping from 'face' to planar or box. Then adjust the values to fit the logo on your model to your liking. Link to comment Share on other sites More sharing options...
videep Posted September 27, 2009 Share Posted September 27, 2009 May be I am wrong but wat i can understand is that you wnat to animate the cylinders??? I think that you can make 8 cylenders so that you have control on each and use the slice option in the MODIFY panel which is just below the "smooth" option. Check it and use the slice....!!! Link to comment Share on other sites More sharing options...
videep Posted September 27, 2009 Share Posted September 27, 2009 You wont be able to find it in the materil editor, But you need to do this: - Select the object, - Go to Modifier list which is just beow the modify panel, - Press the "u" key once the dropdwon list appears, - Select the UVW MAPPING option it may also ve UVW MAP. then when you go to the MODIFY panel, You can change the type of uvw mapping..... Hope this helps Cheers! Link to comment Share on other sites More sharing options...
ezzor Posted September 27, 2009 Author Share Posted September 27, 2009 Thx Link to comment Share on other sites More sharing options...
