acjwalker Posted September 28, 2009 Share Posted September 28, 2009 I have just come in after the wekend off and my autocad 2010 is doing something very strange. The way I usually work is i select an object and then type m to move it, then i move it done. But now i select the object type M it deslect5s everything and i have to select the object again. I know with some commands this is the way you work e.g. slice. But this is getting on my wick, what has happened? I have replaced my acad.pgp file with my own one and it still does it. ANy help? (I am modelling in Acad) Link to comment Share on other sites More sharing options...
Cad64 Posted September 28, 2009 Share Posted September 28, 2009 Type PICKFIRST at the command line and change the setting to 1. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted October 21, 2009 Share Posted October 21, 2009 In a hurry so won't double check if I'm right: Tools: Options: Selection: Noun/Verb. Link to comment Share on other sites More sharing options...
Cad64 Posted October 21, 2009 Share Posted October 21, 2009 Yes, ticking the Noun/Verb checkbox or setting the Pickfirst variable to 1 will achieve the same result. Just two different ways to do the same thing. Either method will solve the problem. In a hurry so won't double check if I'm right: Tools: Options: Selection: Noun/Verb. Link to comment Share on other sites More sharing options...
