Fuzzybear Posted September 28, 2009 Share Posted September 28, 2009 Hello, my name is Fuzzybear and I am a new member. I'm using autocad architecture 2009 and would like any info on the best way to create a stained glass window. Color panels if possible. Thankyou. Link to comment Share on other sites More sharing options...
Cad64 Posted September 28, 2009 Share Posted September 28, 2009 Welcome Fuzzybear. Are you making a 3D model of a stained glass window or a 2D drawing of one? Link to comment Share on other sites More sharing options...
Fuzzybear Posted September 29, 2009 Author Share Posted September 29, 2009 I'm trying to make 3d model of one. Link to comment Share on other sites More sharing options...
Cad64 Posted September 30, 2009 Share Posted September 30, 2009 Ok, so where are you getting stuck? Here's a tutorial on how to create a stained glass window. It was written for 3DS Max, but the same technique can be applied to ACAD. Just draw out your pattern with Polylines and then Extude or Press/Pull the shapes to create Solids. http://www.republicofcode.com/tutorials/3ds/stained_glass/ Link to comment Share on other sites More sharing options...
Fuzzybear Posted September 30, 2009 Author Share Posted September 30, 2009 I will give it a try. Thankyou for the help. I will let you know what happens. Fuzzybear Link to comment Share on other sites More sharing options...
Fuzzybear Posted September 30, 2009 Author Share Posted September 30, 2009 I think I'm going in the right direction for the 3d stained glass window. 1) I first drew a 2d single line window in the shape I wanted with a frame around it. 2) I then offset each line in the field by 1/8" on both sides. 1/4" for the frame. 3) With each part having three lines, I deleted the center line of each. 4) Using the pedit com. I made everything a pline. 5) I converted the outer frame and each seperate pline making up the total frame to a mass element 1/4" thick and the glass panes 1/8" then centerd the panes. 6) I placed the panes on a glaz layer then frooze them. 7) With the outer frame being a solid mass, I subtracted each of the remaing segments from the main mass to create the openings for the glaz. 8) With all the layers on I used the edit object display to override the material to doors & window glazing glass. It gives some eight colors to choose from and made the frame a metal. Then I made it into a block. So far It looks good. I just need to adjust the value for transluscent. A long process but it works. If there is a shorter way I would love to use it. Thanks for your help. Fuzzybear. Link to comment Share on other sites More sharing options...
