SunGlare Posted September 30, 2009 Share Posted September 30, 2009 Yes, I wish. Is there any script that helps, manages, supports transfering simple geometry to older versions of max? We received some files that were saved with newest possible version of it, but features in this file reach only to Max R9. When I was forced to use such, I managed to get things thru by using Vray proxy feature, but still had some issues with material being not compatible. Any thoughts? Thanks. ..and yes I've Googled the matter. Link to comment Share on other sites More sharing options...
Jan Posted September 30, 2009 Share Posted September 30, 2009 Try exporting in fbx format, wich preserves the geometry, textures and animation. Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted September 30, 2009 Share Posted September 30, 2009 you can use BFF (Bobos file format aka Back from Five) but you need to remove features that do not exist in the older version, IE: Going from max2010 to max2008, you would need to remove all Color Correction maps because that did not exist at the earlier version.. etc It can be done, it kinda sucks Link to comment Share on other sites More sharing options...
