wierd shadows on flat surfaces (possible simple fix)
dave_C
Im in the process of teaching myself VRay and have hit a little snag.
iv been at this all day, and its driving me up the wall.
I tried to render off a WIP image of this interior and im getting a strange textured appearance on what should be perfectly flat white walls
The textures are both max defaults (for test render) one white for most of the model, one white at 20% opacity for glass and it has a VRay sun, with VRay sky in env slot
can anyone tell me what im doing wrong?
and how to fix it?
massive thanks to anyone who can.
according to me , i feel these weird shadows and blotches appear because of not sufficient light entering the room.
increase the glass transparency further ,add vray plane light at the window.
if you are using vray phy camera then try f8,iso 60,shutter speed 120.
in ur settings,
i would tweak a bit.
try adaptive sub div with catmul rom
in color mapping check sub pixel mapping,clamp output,affect background.
try with hight light cache sub div .around 600
cheers!
just so you know this is a very short animation piece hence having it on world rather than screen
i rendered off with much higher settings than previously posted and im still having issues
BIG thanks for all the help so far, the render has improved massively
still more help needed with this though, thanks
if you want to see what happening now if you go to youtube and type in "Test render4" im scavangereight it should be the first one, would post a link but not allowed to :(
thanks
