Justyn Stevens Posted October 8, 2009 Share Posted October 8, 2009 Hello all, I have an annoying problem whilst rendering a 3DSMax/VRay animation. Every now and again a light emplosion will appear on a surface and will fade in and out like a small/slow explosion or like a flash-bulb going off. I have vray sun and some vray lights as well as Vray light material and IES lights in the scene so it's a bit light heavy. But everything else looks good, so coul this be an IR map fault? I rendered at Medium animation 50/20. Any help would be much appreciated Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 8, 2009 Share Posted October 8, 2009 can you post the animation, it hard to tell what's going on. Link to comment Share on other sites More sharing options...
Justyn Stevens Posted October 8, 2009 Author Share Posted October 8, 2009 I'm not sure of the best way to do it, so here is a zipped up FLV file, hope that's ok! J. Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 8, 2009 Share Posted October 8, 2009 Is there anything behind that wall that could be intersecting it at those two points? Link to comment Share on other sites More sharing options...
Tommy L Posted October 9, 2009 Share Posted October 9, 2009 Ive not seen that before. I think its unlikely to be co-planar geometry, that usually goes darker and flickers rather than the smooth 'on-off' transition you have there. More likely its a pre-calc lighting error. Other than that, I can only think that maybe you have a couple of accidental caustics. Link to comment Share on other sites More sharing options...
