DIST command list in AutoCAD
SandmanNinja
SHORT TITLE FOR SUGGESTION/BUG/ENHANCEMENT REQUEST
DIST
DETAILED DESCRIPTION OF YOUR REQUEST
A command that behaves like the DIST command in AutoCAD.
The DIST command is so good in AutoCAD. I can click on 2 'verts' and it will give me the distance in a straight line as well as the X offset distance and the Y offset distance, as well as the angle between the two.
WHY THIS REQUEST IS IMPORTANT TO YOU
I often toggle back and forth between AutoCAD and 3ds when working with an imported DWG file.
For 3ds scenes without an AutoCAD file, it would be nice to have the same information that the DIST command provides.
I added the tape measure to my right-click menu
so,i press "S", right-click, measure, vert -> vert and keep listener window open on my left monitor
I guess I missed what you were saying, Stan.
If I use it in a different viewport, it gives me straight-line as well as only x and only y?
if you need just a vertical measurement - you are better off viewing the model in left/right/front etc viewports - then you can see that your measurement is horizontal. For example if you have just imported a 3d person and need to make sure that they are about 160cm or so tall.
but if you need a specific measurement - tape helper is good. not as good as autocad dist command ;)
  • 1 month later...
I never noticed this but if you use the distance tool in max and make sure you dont move the mouse after you've clicked the second point, down in the status bar it will infact give you a distance measurement as well as a Delta X, Y and Z!
Interesting to note that the listener window doesn't return these values thought :rolleyes:
edit: you can move the mouse, but as soon as your cursor snaps to a point it will change the status bars readout and you will lose your measurement info.
