DR problem: Slave Died.
Tommy L
Besides sounding quite funny, this error is killing Max and MR as soon as a render completes.
Im using Distribuited Rendering over 8 nodes. It was working fine, now it isnt (grrr). Dies during 'cleaning up' phase
Error says:
mental ray has encountered a fatal error and the application will now shutdown. The error is:
PAR 0.0 fatal 021512: SLAVE (#) DIED
Any help anyone? I mean come on, slave dies cleaning up?
Thanks,
Tom.
Wow - I never work my slaves that hard!
Don't see how a dead machine would cause a mental ray error...
good luck
Well Im pretty new to MR so I dont know either.
Does anyone know how MR assigns a number to the nodes? Ther error I typed above always comes up with a number to identify the dead machine, but its a fairly arbitrary number. I typed in the ip addresses in the render panel to assign the nodes. I noticed that when I check the ip addresses from my workstation (in the backburner monitor) they have different number than the ones I assigned. Does that mean I have floating ip's on the network? Will that affect MR?
The clean up stage is when mr dumps all the info its been holding in memory. I have had this before and in my case a simple reboot fixed it.
Try assigning one machine at a time to see if it crashes on any particular machine. Also keep an eye on the message window to see what machine is doing what.
What BSB methode are you using? BSB or BSB2.
jhv
Im using BSB (just because thats the default).
The death is fairly random. It doesnt happen every time and Im not seeing any correlation between the scene and the fatality...
Problem is it doesnt tell me which machine dies. Its a fatal error, so the mr log doesnt tell me anything.
I really hope its not a compatibilty issue between W7 and XP64 on the network :(
