kwdll Posted October 14, 2009 Share Posted October 14, 2009 I've got the Maxwell for Cinema 4D Plugin Manual where it says: If any non-plugin-related parameters are not explained sufficiently here, please consult the regular Maxwell Render manual for further direction. Where do I get the Maxwell Render Manual? Thx! Link to comment Share on other sites More sharing options...
mattclinch Posted October 14, 2009 Share Posted October 14, 2009 (edited) it should have been an option to download when you purchased the software. if you didn;t get it try logging in to the maxwell portal? EDIT - full manual here - http://think.maxwellrender.com/maxwell_render_v2__manual-297.html Edited October 14, 2009 by mattclinch Link to comment Share on other sites More sharing options...
kwdll Posted October 14, 2009 Author Share Posted October 14, 2009 Thx a lot! Link to comment Share on other sites More sharing options...
Tella Posted October 15, 2009 Share Posted October 15, 2009 Your V2 installation should have it already. Link to comment Share on other sites More sharing options...
dannydesil Posted November 27, 2009 Share Posted November 27, 2009 I use Maxwell and it appears that your camera is not focusing on the object. In the HUD display you have that option turned on, if you make it active will show you the distance to the object. Make sure that you Maxwell camera is set to the distance to focus to. I found that to be the thing that frustrated me about Maxwell when I first started. I may be wrong, but I think I see that happening with yours. And 12 to 18 hours with Maxwell is not uncommon. Link to comment Share on other sites More sharing options...
