Stan Zaslavsky Posted October 15, 2009 Share Posted October 15, 2009 hi there, here is an interesting request from a client. is there a way to remove reflections from mirrors - he wants the mirror to be clear. aside from doing this in photoshop - is there a way to exclude objects from being reflected in a mirror surface? Link to comment Share on other sites More sharing options...
luckyluc Posted October 15, 2009 Share Posted October 15, 2009 This is really funny. a mirror that is not reflecting. A mirror is normally made to reflect everything. You can rightclick the object, then unclick visible to reflection. Renders faster to. Or maybe select the mirror in photoshop, and blur it, or give it some colour, to make it reflect less. Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted October 15, 2009 Author Share Posted October 15, 2009 thanks Luc - some clients expect that in virtual reality - things can appear unreal typical story Link to comment Share on other sites More sharing options...
WAcky Posted October 15, 2009 Share Posted October 15, 2009 Is it supposed to be not reflecting a particular object or just not reflecting anything at all? Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted October 16, 2009 Author Share Posted October 16, 2009 i used a different material in the end for the mirror - which had some smoky cloudy effects inside and didnt show any reflections at all - and so the client was happy with that. thanks for all your help Link to comment Share on other sites More sharing options...
DanGrover Posted October 16, 2009 Share Posted October 16, 2009 i used a different material in the end for the mirror - which had some smoky cloudy effects inside and didnt show any reflections at all - and so the client was happy with that. thanks for all your help I thought he wanted a mirror, not a portal to Mordor! Haha, I love things like that. A mirror is its reflections! Well done for keeping the client happy though with such a bizarre request! Link to comment Share on other sites More sharing options...
Stan Zaslavsky Posted October 16, 2009 Author Share Posted October 16, 2009 hey dan thanks for your comments - yeah some clients expect virtual reality to be unreal a portal to mordor hehehehhe - i'll use that next time in the explanation to them all the best Link to comment Share on other sites More sharing options...
Alex York Posted November 30, 2009 Share Posted November 30, 2009 that should be in one of those "clients from hell" request lists. not unlike "can you make that black lighter, but without making it grey?". Link to comment Share on other sites More sharing options...
Tommy Burns Posted November 30, 2009 Share Posted November 30, 2009 Or "can you make the glass more reflective and more transparent"???? Link to comment Share on other sites More sharing options...
hie5 Posted January 4, 2010 Share Posted January 4, 2010 hi there, here is an interesting request from a client. is there a way to remove reflections from mirrors - he wants the mirror to be clear. aside from doing this in photoshop - is there a way to exclude objects from being reflected in a mirror surface? Really an interesting request I must say. Haven't come across one like it Link to comment Share on other sites More sharing options...
css20xx Posted June 14, 2010 Share Posted June 14, 2010 Is quite simple: Select the object that you don't want to see it in the mirror, Right Click, Object Properties, and deselect "Visible to Reflection/Refraction". See this picture: [ATTACH=CONFIG]37579[/ATTACH] Or if you use "Vray": Select the object that you don't want to see it in the mirror, Right Click, V-ray properties, and deselect "Visible in Reflections". Link to comment Share on other sites More sharing options...
Graphite Posted April 8, 2011 Share Posted April 8, 2011 "I'd like a photo-real renderings"..... 1 Day Later.... "Can you make the sun purple?".. lol *shakes head* Link to comment Share on other sites More sharing options...
geo971986 Posted December 21, 2011 Share Posted December 21, 2011 Hello all. (my first post here Is it possible to remove an object reflection only from one of the reflective objects? For example If a have 2 mirrors and I want to remove the sphere reflection only from one of the mirrors. Thank you. Link to comment Share on other sites More sharing options...
410 Posted January 4, 2012 Share Posted January 4, 2012 Is it possible to remove an object reflection only from one of the reflective objects? As far as I am aware 3ds Max (or Maya for that matter) does not allow selective reflections. So you can't say selectively specify "this sphere object visible to reflections in Mirror 1 but not in Mirror 2". You can specify a maximum reflection distance in Arch & Design materials, but that usually won't give you the effect you're looking for, because (obviously) nothing behind the object you don't want reflected will be reflected either. There is a way of setting up a camera to capture what a mirror would reflect and then using that output as the 'false' reflection, but in all honesty it's a pretty time consuming and labour intensive process. Far simpler is just to render 2 passes and composite them appropriately in post production. Something like this: [ATTACH=CONFIG]46506[/ATTACH] This method does have it's drawbacks: particularly for scenes with very long render times or for complex animations. But by and large I'd imagine that it's going to be your best bet. Link to comment Share on other sites More sharing options...
geo971986 Posted January 4, 2012 Share Posted January 4, 2012 Thank you Alex for your answer. I was afraid that compositing will be the only acceptable solution. It is a bit time consuming in my case since I have an animation but at least I know I don't miss any easier solutions. Link to comment Share on other sites More sharing options...
artmaknev Posted December 21, 2012 Share Posted December 21, 2012 This is the most common client request, I get that almost all the time, "please remove reflection of lamp, remove reflection of tree......." Link to comment Share on other sites More sharing options...
jaysean Posted December 26, 2012 Share Posted December 26, 2012 Sure, i easily can remove reflection from mirror in photoshop. There are many ways to remove it, you can send me picture i can resend you with remove reflect. Link to comment Share on other sites More sharing options...
Umesh Raut Posted January 4, 2013 Share Posted January 4, 2013 Sure, i easily can remove reflection from mirror in photoshop. There are many ways to remove it. Very true, and if you render separate passes, its much much easier in any image compositor. Link to comment Share on other sites More sharing options...
bindunarayan Posted March 8, 2013 Share Posted March 8, 2013 One of the most bizarre request I have ever heard about so far. A mirror without any reflections! Sounds really funny. Here, the client is asking to nullify the basic characteristic of the mirror i.e. reflection, and I suppose there must be a genuine reason for such a bizarre requirement. Link to comment Share on other sites More sharing options...
cg_Butler Posted May 17, 2013 Share Posted May 17, 2013 thanks Luc - some clients expect that in virtual reality - things can appear unreal typical story I was once told by a client "Andy, there is what's real in the real world and what's real in a CGI rendering" and my personal favorite "It needs to be more blue but less blue....." They do come out with some funny requests don't they! But, they are always right, right? ;-) Link to comment Share on other sites More sharing options...
