djoshi Posted October 16, 2009 Share Posted October 16, 2009 hi, I have rendered aniamtion with saved IM - multiframe incrimental & LC - flythrough. But I am getting flickers in trees, now I really dont hv time to do any change in render settings & rerender. so, in AE or with some post technic can i reduce this flicker atleast to some extent. has anyone done it before?? urgent help require.. Thanx in advance.. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted October 16, 2009 Share Posted October 16, 2009 I think there is an effect in after effects called Color Stabilizer which will smooth out changes in brightness between frames. I've never tried using it for this problem but it might be worth experimenting with. Link to comment Share on other sites More sharing options...
Nic H Posted October 16, 2009 Share Posted October 16, 2009 best to learn to use vray i reckon, then search the forum. other than that you are just going to have to blur it. Link to comment Share on other sites More sharing options...
AndyC Posted October 16, 2009 Share Posted October 16, 2009 Agreed, could be a number of things . . . also depends on wether the trees are native geometry of RPC etc . . . Is it a lot of frames? Or just one or two, how spaced out are they? AFX CS4 has a nice timewarp effect using pixel motion, it traces pixels to create new frames, its miles better than frame blending and might do the trick. Might be worth a try playing around with that. Link to comment Share on other sites More sharing options...
