remKa Posted October 19, 2009 Share Posted October 19, 2009 Hello guys, I'm trying to render an AO pass with vray lightMat + vray dirt in the override material slot, but i always get a full white image...I tried to use the well known script, same thing happened. I turned GI on and off, turned all my lights on and off, uncheck "hidden lights", turned the gi environement override and the environement map on and off as well I tried also the vray extratex + vray dirt in render elements section, no luck neither. I don't understand :/ Link to comment Share on other sites More sharing options...
WAcky Posted October 19, 2009 Share Posted October 19, 2009 The easiest way by far is the Extratex method. What was the problem when you tried this method? It might be a good idea to post some pics of your setup. Link to comment Share on other sites More sharing options...
remKa Posted October 19, 2009 Author Share Posted October 19, 2009 I get a full white image too :/ http://img269.imageshack.us/i/82083038.jpg/ In this exemple, I let the lightning with GI (irradiance map and light cache) "ON" + Vray environement override Link to comment Share on other sites More sharing options...
Brian Smith Posted October 19, 2009 Share Posted October 19, 2009 Here is a 3 page tutorial I wrote on AO that should help. http://3dats.com/london/3DATS_Ambient_Occlusion_Tutorial.zip Link to comment Share on other sites More sharing options...
remKa Posted October 19, 2009 Author Share Posted October 19, 2009 I used Hampton_Inn-AO, I selected camera 1 and hit render, here is what I get :/ http://img269.imageshack.us/i/hamptoninnao.png/ Link to comment Share on other sites More sharing options...
WAcky Posted October 19, 2009 Share Posted October 19, 2009 When you use the extratex pass, you don't need to change any render settings. It should render out along side your beauty pass just fine. Be sure your units are set up correct because with an AO distance of 1 meter that sphere will need to be pretty big for the AO to show. Can you upload a basic scene setup and I can have a look at it for you? Link to comment Share on other sites More sharing options...
Nic H Posted October 19, 2009 Share Posted October 19, 2009 yep use extratex element with radius set correctly. Dont use that crappy plugin. Link to comment Share on other sites More sharing options...
remKa Posted October 19, 2009 Author Share Posted October 19, 2009 I will put a basic scene in 5 minutes Link to comment Share on other sites More sharing options...
remKa Posted October 19, 2009 Author Share Posted October 19, 2009 here we go Link to comment Share on other sites More sharing options...
WAcky Posted October 19, 2009 Share Posted October 19, 2009 hrm. Strange. It seems to work fine for me but I'm using a newer version of Vray and max to you. I would try the most basic scene setup you can do. Plane. teapot Physcam vraysun turn on GI enable VFB add your extratex with dirtmap loaded. pay attention to the size of your object and the dirtmap radius. goooood luck. Link to comment Share on other sites More sharing options...
remKa Posted October 19, 2009 Author Share Posted October 19, 2009 AO is still full white Link to comment Share on other sites More sharing options...
trino Posted October 19, 2009 Share Posted October 19, 2009 is working fine here too. Are you using a DEMO version without water mark ?? maybe that´s the problem.....if you know what i mean. Link to comment Share on other sites More sharing options...
remKa Posted October 19, 2009 Author Share Posted October 19, 2009 Yep, I think that's the problem here :/ Link to comment Share on other sites More sharing options...
Brian Smith Posted October 20, 2009 Share Posted October 20, 2009 Well I don't know what the problem is, but the steps in the tutorial work. Good luck. Link to comment Share on other sites More sharing options...
re vit Posted October 20, 2009 Share Posted October 20, 2009 (edited) I heard some DEMO versions without water mark have spoiled vraydirt.dlr. Get a healthy one Edited October 20, 2009 by 1rv Link to comment Share on other sites More sharing options...
remKa Posted October 20, 2009 Author Share Posted October 20, 2009 Awesome, thanks ! It's working now Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 21, 2009 Share Posted October 21, 2009 What about using the AO option under the Indirect illumination rollout? Link to comment Share on other sites More sharing options...
remKa Posted October 21, 2009 Author Share Posted October 21, 2009 There is no AO option in Vray 1.5 sp2 ^^ Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 21, 2009 Share Posted October 21, 2009 Sorry I didn't see which version you were using, it's only in SP3. Link to comment Share on other sites More sharing options...
