SandrineBoulard Posted October 19, 2009 Share Posted October 19, 2009 Hi there, I'm working on a teen bedroom, comments and advices are highly welcomed Thx, Link to comment Share on other sites More sharing options...
SandrineBoulard Posted October 20, 2009 Author Share Posted October 20, 2009 here is the girl version thanks in advance for your comments Link to comment Share on other sites More sharing options...
kippu Posted October 20, 2009 Share Posted October 20, 2009 for starters fix the camera so that we have a two point perspective instead of the three point one ..... after that maybe get some shadows in , maybe sunlight if it pleases you? Link to comment Share on other sites More sharing options...
SandrineBoulard Posted October 20, 2009 Author Share Posted October 20, 2009 thx kippu for your comment, I'll update it accordingly and will post it then Link to comment Share on other sites More sharing options...
SandrineBoulard Posted October 20, 2009 Author Share Posted October 20, 2009 another kid bedroom with a different pov kippu, doest it match what you are refering in your previous comment ? thx for your advices Link to comment Share on other sites More sharing options...
remKa Posted October 20, 2009 Share Posted October 20, 2009 Toujours un point de fuite en trop, qu'est-ce que tu utilises comme logiciels ? Link to comment Share on other sites More sharing options...
SandrineBoulard Posted October 20, 2009 Author Share Posted October 20, 2009 Toujours un point de fuite en trop, qu'est-ce que tu utilises comme logiciels ? j'utilise essentiellement 3dsmax+vray+photoshop aurais-tu un exemple d'une vue avec un point de fuite mieux adapté ? merci --------------- I'm using mainly 3dsmax+vray+photoshop would you have a sample render showing fixed point perspective ? thanks Link to comment Share on other sites More sharing options...
remKa Posted October 20, 2009 Share Posted October 20, 2009 Il faut que toutes tes verticales soient parallèles, le plus facile pour ça, c'est d'utiliser une vray camera, et dans les options de celle-ci, cliquer sur "guess vertical shift" Link to comment Share on other sites More sharing options...
SandrineBoulard Posted October 20, 2009 Author Share Posted October 20, 2009 Il faut que toutes tes verticales soient parallèles, le plus facile pour ça, c'est d'utiliser une vray camera, et dans les options de celle-ci, cliquer sur "guess vertical shift" merci pour l'astuce je vais les refaire du coup pour le reste, que penses-tu de mes différentes réalisations ? Link to comment Share on other sites More sharing options...
remKa Posted October 20, 2009 Share Posted October 20, 2009 les différentes athmosphères sont bien retranscrites, après en terme de design je ne suis pas fan, mais les goûts et les couleurs hein . D'un point de vue rendu, ça manque de précision, c'est assez flou, quels sont tes settings vray ? Link to comment Share on other sites More sharing options...
guiltybydesign Posted October 20, 2009 Share Posted October 20, 2009 I think the guitar in the first one is too big..or maybe the couch is too small.. Link to comment Share on other sites More sharing options...
SandrineBoulard Posted October 21, 2009 Author Share Posted October 21, 2009 thank you guys for your comments, I'll get back @ work and apply these advices Link to comment Share on other sites More sharing options...
