Noise Posted October 21, 2009 Share Posted October 21, 2009 I have a scene which opens and it can be worked on however, there are many rendering issues, problems and crashes. How can I find out whether the file is corrupt or if there is something in the scene which is playing up? Thanks N Link to comment Share on other sites More sharing options...
mattclinch Posted October 21, 2009 Share Posted October 21, 2009 the old trick is to merge objects one by one from the corrupt scene into a new, fresh scene which renders fine and see which object is causing the errors. Link to comment Share on other sites More sharing options...
Noise Posted October 21, 2009 Author Share Posted October 21, 2009 Yeah, I've done that numerous times and even identified a problematic piece of geometry and replaced it. Then it happens again - then the net rendering fails, then the model crashes on opening. I have actually sorted out the crashing on opening but can't figure out why certain animated geometry renders black for no reason. Fun and games. Link to comment Share on other sites More sharing options...
Tommy Burns Posted October 22, 2009 Share Posted October 22, 2009 It may be that one of your texture maps are too big or corrupt Link to comment Share on other sites More sharing options...
Noise Posted October 22, 2009 Author Share Posted October 22, 2009 There is one big texture but I have tested it and its not that unfortunately. Link to comment Share on other sites More sharing options...
itarc Posted October 29, 2009 Share Posted October 29, 2009 I think you have the problem with texture. You need check all link of Texture in your scense. Link to comment Share on other sites More sharing options...
itarc Posted October 29, 2009 Share Posted October 29, 2009 File / acess tracking Link to comment Share on other sites More sharing options...
