colorID Posted May 11, 2003 Share Posted May 11, 2003 hi every one, did anyone be4 tried to import maya files into max or viz? i heard about using the dxf export from maya then import it into max.. but everything is lost there :S is there a good way or exporter to get maya files into max? plz tell me thnx Link to comment Share on other sites More sharing options...
plastic Posted May 11, 2003 Share Posted May 11, 2003 what is lost there? i managed to import geometry from maya users into max, via dxf (polys) or iges (nurbs). Link to comment Share on other sites More sharing options...
Diego Rosales Posted May 11, 2003 Share Posted May 11, 2003 I've had the same problem before. After exporting everything into DXF, nothing comes up in MAX. IGES seems to work better. I've also heard about OBJ importers for max. /Diego Link to comment Share on other sites More sharing options...
ferox Posted May 12, 2003 Share Posted May 12, 2003 there are probably several and various recipes for this, depending on the export model contents. one precautionary approach ( iff geometry is an issue) is to export an .obj file from maya; view/check/analyse the exported file's geometry using okino's polytrans or 3d exploration; and continue with importing into max if all is well... dxf and 3ds file formats have known limitations? Link to comment Share on other sites More sharing options...
colorID Posted May 13, 2003 Author Share Posted May 13, 2003 helloevery one... dxf exporterhas problem with the geomtry gathering ... i was wondering about the IGES exporter how to do it ? thnx every one Link to comment Share on other sites More sharing options...
kid Posted May 13, 2003 Share Posted May 13, 2003 get the .obj importer for Max at maxplugins.de then bring the .obj files into Max. There's sometimes flipped normals on open surfaces but closed objects should be fine. I've had success with quite complex models. Link to comment Share on other sites More sharing options...
John Dollus Posted May 14, 2003 Share Posted May 14, 2003 Um...download the Kaydara FBX translators free from their website. Animation translates as well minus deformations. Materials will not translate as there really is not a compatible structure between the two. Link to comment Share on other sites More sharing options...
