Trevor Tizard Posted October 22, 2009 Share Posted October 22, 2009 Hi, I've done a search on this but no luck so far. On Max 2010 when I go into the the poly mode in an editable poly the faces are sub devided into triangles, which is most annoying and difficult to see. Previous versions did not do this. If anyone knows some way of solving this issue, I'd be most grateful. Thanks. Link to comment Share on other sites More sharing options...
WAcky Posted October 22, 2009 Share Posted October 22, 2009 check this setting Link to comment Share on other sites More sharing options...
Trevor Tizard Posted October 22, 2009 Author Share Posted October 22, 2009 Seems to be an open GL display thing. Nt happening with Direct 3D. Link to comment Share on other sites More sharing options...
WAcky Posted October 22, 2009 Share Posted October 22, 2009 interesting. I recall there are some settings in the driver setup that can alter how a mesh is displayed. If you go to customize>preferences>viewport tab then if you have a DX driver loaded click configure driver. There is an option called display all triangle edges which i assume is the setting you're talking about. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted October 22, 2009 Author Share Posted October 22, 2009 Yep, that's the one. Has solved that issue bit now randomly blanks the working area for a second or so. Guess I'll have to live with that though. Thanks for looking. Link to comment Share on other sites More sharing options...
WAcky Posted October 22, 2009 Share Posted October 22, 2009 So are you using a DX driver now? If so and you're using version 10 it's super buggy for me. version 9 is stable. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted October 22, 2009 Author Share Posted October 22, 2009 Yes, using Direct 3D now, but version 9.0. Link to comment Share on other sites More sharing options...
WAcky Posted October 22, 2009 Share Posted October 22, 2009 yeah I've always had issues with max's viewports blanking and menu's just disappearing. I find hitting F3 and F4 a few times refreshes the viewport. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted October 22, 2009 Author Share Posted October 22, 2009 Cheers mate. Link to comment Share on other sites More sharing options...
