Macer Posted October 22, 2009 Share Posted October 22, 2009 I'm working on an animated bubble (picture a large soap bubble) and have to be able to overlay it onto a web page afterwards (don't ask!). I've resorted to using hdri environment to get nice reflections and a realistic looking bubble, but the hdri appears in the background too. My alpha channel is showing completely white for behind the bubble (black outside it though) meaning that when I go to overlay it, I get no transparency for the bubble - the background is still there (but it does cut out around the outside of it), you can see the hdri environment through the bubble - which I don't want, as well as in the reflections, which I do want. I'm sure that there is an easy way to render without the hdri showing up but my brain stopped working and I can't figure it out - Its not like I've spent a lot of time making bubbles before! I can't use the reflection slot because that contains the maps that give me the rainbow like swirl of colours.... Like I said, I'm sure it simple, but help please? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted October 22, 2009 Share Posted October 22, 2009 For the background, try the "Environment/Background Swither (mi)" shader. It will allow you to separate the environment reflections from the background image. As for the alpha... Not 100% sure, but if using a A&D shader, double check that the "Transparency propagates Alpha channel" is ticked. It is under the Advanced Rendering Options in the A&D shader roll out. If that doesn't do it, maybe try the process background and environment under the exposure roll out. Link to comment Share on other sites More sharing options...
Macer Posted October 22, 2009 Author Share Posted October 22, 2009 Great, thanks for the reply. I'll have a play with your suggestions tomorrow. Cheers. Link to comment Share on other sites More sharing options...
Macer Posted October 24, 2009 Author Share Posted October 24, 2009 Thanks Crazy. Your tips were bang on! Just what I needed, they worked a treat. Link to comment Share on other sites More sharing options...
