kid84 Posted October 28, 2009 Share Posted October 28, 2009 hey guys. im new here, hope to get some help. i've been using vray for 3 years+ but 1st time i encounter such issue. recently my boss just bought 2 new pc with window 7, 64bit OS. so i installed both 3D max 32bit n 64bit. the problem occur when after i installed vray for on 32bit max. installing vray over 64bit seems to be fine. but over 32bit, my vraysun and vray physical camera is missing. i dont know why. im using vray adv 1.5 sp2 heres the screen shoot. http://img23.imageshack.us/i/90611669.jpg/ http://img30.imageshack.us/i/75826486.jpg/ the funny part is that i install on the other pc for my colleague, which of coz im using same method same way to install the vray. his pc seems to be fine with it. loading the vray sun and vraycam perfectly. does anyone encounter such problem? need help pls... Link to comment Share on other sites More sharing options...
Thablanch Posted October 28, 2009 Share Posted October 28, 2009 You can load them by going: Customize > plugin manager. They are in the folder, but not showing. (Do not know why your install did now work proprely, but that's a workaround) Link to comment Share on other sites More sharing options...
rgb Posted October 28, 2009 Share Posted October 28, 2009 i there, this happend to me once when i was using Vista, and the soloution was to make sure you run 3ds max as administrator by right clicking it and choosing run as administrator. haven't tried windows 7 yet. Link to comment Share on other sites More sharing options...
kid84 Posted October 29, 2009 Author Share Posted October 29, 2009 it is cool to hav u guys here replying. thanks man... You can load them by going: Customize > plugin manager. They are in the folder, but not showing. (Do not know why your install did now work proprely, but that's a workaround) yeap, what u said is correct. the 3D max didnt load the entire vrayplugins for some unknown reason. got to load it 1 by 1. i there, this happend to me once when i was using Vista, and the soloution was to make sure you run 3ds max as administrator by right clicking it and choosing run as administrator. haven't tried windows 7 yet. yea, window 7 seems to be the same too. got to run as administrator. but it is kinda annoying and i test quite a lot. and i think it got issue when comes to backburner. what i do is i disable the UAC. then everything just run normally without having to click run as administrator. thanks Thablanch and rgb for the info. both are helpful for me. btw Thablanch, is there anyway for me to load those plugin manually just once? coz 3D max doesnt seems to load the plugin settings after i restart it. Link to comment Share on other sites More sharing options...
Thablanch Posted October 29, 2009 Share Posted October 29, 2009 I'm sure there a way to do a script in the startup script directory that could do that, (but I do not know much about scripts.. I use them ,but do not write them.) Link to comment Share on other sites More sharing options...
kid84 Posted October 30, 2009 Author Share Posted October 30, 2009 I'm sure there a way to do a script in the startup script directory that could do that, (but I do not know much about scripts.. I use them ,but do not write them.) i see. thanks for enlighting. Link to comment Share on other sites More sharing options...
