Help me dig
Devin Johnston
I've got an AXYZ character with mocap data applied that is doing the motions of digging with a shovel. I have a shovel that I want him to use and I've tried linking the shovel to the mesh of the character but that doesn't work. Anyone have some advice on how to put the shovel in his hands and have it follow his movements?
Biped motion capture rigging typically has a standard bone structure and convention of set up. If I remember the hand/palm or wrist has an intrest/control null that you maybe able to use to control the position and rotation of the shovel. If not you might be able to child a null and or shovel to the palm bone center-pivot.
If you can get that set up without wonking the motion capture driven animation it shouldn't ne too hard to have the left hand control the position and rotation of the shovel based on the palm and a controller to keep the shovel fixed to the other hand. Really if it's motion capture of a human shoveling the right hand may line up with the shovel handle by default..... I doubt it though.
My thoughts, hope they aren't too arcaic. Have attached objects in Motion Builder way back when and it looks like MAX has implemented that functionality without the interface that made Motion Builder really pretty easy. Sweet app before AD to work with animation, motion capture and transfer there of.
AXYZ's documentation is just plug and play type stuff, so it's hard to tell at a glance just how the charactor is rigged-though there is a uniform 'rig' set up associated with motion capture. Find and verify the rig stucture-------may get some ideas on how to connect up a shovel based on the structure.
Cheers
Wda
Not to be a party pooper on the animated character, but are sure you are not over thinking this shot? .....I am not sure what you are doing, or how close you are to your subject. But... I do feel if you are close enough to notice the positioning of a shovel in a 3d characters hand, then it might be worth approaching the shot from a different process.
If you are close enough to notice the shovel swing, then it might be worth investigating a video photo composite option. If you are far enough, maybe the positinig you have is fine, or maybe you can do a animated paint composite over the character?
The guy digging is the center of attention in this shot, unfortunately they want to see him performing this action so I can't really hide it. I've already tried linking the shovel to the hand/bone but it just screwed up the shovel and the mesh of the character. I'll give it a try again but right now animating a gizmo or doing it the way WDA described seem to be my only options. I haven't done much charactor work but every time I mess with it I'm always amazed at how primitive the interface is. It would be nice if AutoDesk would spend some of my subscription money and bring some of the tool interfaces out of the 90's.
If your shovel will not link to the hand bone then you have messed something up in the hierarchy. If you have scaled any of your bones rather than using the interface to scale then this scaling is inherited by the children ie the shovel. You can disable inherited scale which may sort things out. The key to boning any mesh is that you always reset the xform values prior to enabling physique. The software interface has come on considerably since the 90's I can assure you as one of the older users
Edited by JonRashid
Spelling
cool, it's getting there. What you could do with the other hand is link its bone to
the spade. However you will need to remove all the keys from the left arm. If you do that and then link the hand to the spade the IK in the biped should solve itself. You may have to correct it at some point as twists can some times need assistance. So at the end your right hand would control the movement of the spade which subsequently controls the movement of the left hand. You could also try it the other way around, without looking at the anim closely it's hard to make a decision as to which would be best as the master. If you find your hand is revolving around the handle you may have to add an intermediary step.
If this causes a problem you will have to look at what inherited links are past on and disable the z/x/y (whichever is the relevant 1). If you line your shovel up properly at the beginning you should find that its main axis would line up with your hand and this would result in your child hand going with the shovel during the anim but not sliding about. Sorry about length of reply but not used to explaining things without a pc
Hold on there maxer. I forgot that might cause a loop you cant have. Your second hand can't be a child cause its already in a hierachy with your other hand. Sorry about that. I have done a similar animation although it's 6yrs now since I did character animation so your accessing old memories. I will have a play and sort out how i did it last time
  • 2 weeks later...
