new_xieland Posted October 30, 2009 Share Posted October 30, 2009 Okay I'm just starting to get into 3ds max 9 and vray 1.5 and hope if you guys could shed a little light on my problem. Say I have a texture - when I apply a bump map (bitmap to be exact), it's okay, shows us up in the material editor with the correct effect. Now when I try to do the same for it's diffuse map (again a bitmap image), it completely over-rides my bump map settings so that I can no longer see my bump map effect. So it is saying that you can only have on bit map image applied ? Cheers Link to comment Share on other sites More sharing options...
Thablanch Posted October 30, 2009 Share Posted October 30, 2009 It does not mess with your previous map. It is just that you do not "feel" your bump map as much, as you are not seeing it on a solid color anymore...It is still there Your material can be composed of many maps, (and get as complex as you want.) Link to comment Share on other sites More sharing options...
