3 Problems in my First Interior Scene
alless
Hi ,
first plz Look at my Render :
As you see ... I have 3 problems in the scene :
1 - Glass Renders Awful - well glass in the left Partition Is unrealistic , Reflection is not Logical and Blurred so much ...
But in the Reality that Glass have True Reflection and Gloss .... Here is my Glass Material Settings :
I Render it with IR+LC and scene has Vray sun/sky ...
2- Wood renders in Low Quality - as you see the Desk at right side got Wood texture with High quality but when it rendered
It Looks Awful and Details of Texture are all Dead ... Also it's Glossiness doesn't Show itself .
3- Noise On Roof - As You see whole image doesn't have Noise but only top right on the roof the seems to be Noisy ...
I don't know which Parameter Can Fix that ...
I'll be Really Appreciate your help ,
Let me try to help you:
1- Why would you need glossiness in your glass' reflections? Simply put 1.0 and you're set, nothing else. Also, you don't need to change the subdivs unless you are using glossiness
2- The wood texture is rendering like that probably because of your Image Sampler settings. What are you using?
3- This kind of problem often happens because your lights have low subdivs. I don't know which lights you have there (besides the sun and sky), so it's kind of hard to tell exactly. But I would increase the subdivs to 32 (I'm guessing here).
Thanx For your Nice help dude ,
Here is my Second render after your Suggestions :
My Third Problem Totally Solved by Increasing Vray Light Subdivs to 32 ! Thanx a World ! ;)
My Second Problem Also Solved Cause I was Using "Adaptive Subdivision" as IMage Sampler , Now I changed to "Adaptive DMC" with 1 to 4 Subdivs (min to max) ... (Any way I Really donnow when to use which Image sampler ?!)
My First Problem Still Exists ... but Glass Improved So Much as I Turned Glossiness Off .... but I don't See Any Reflection on Glass ... when I look at That glass in Reality I see Reflection of Ground and and Other Objects on it about 50% ... But here I see only Reflection of Light that placed on Ground .... Any other Parameter needed for that ?
  • 3 months later...
