clarkeme Posted November 2, 2009 Share Posted November 2, 2009 Hi again Hopefully this is a simple one. I have created a model, and then created a new Material library based on the materials I have used in this model. However some materials now come up as just grey circles in the browser. They seem to have lost there maps ( or map locations). Does the fact that my material browser now shows red circles, mean these are in error? Many thanks again Link to comment Share on other sites More sharing options...
SandmanNinja Posted November 2, 2009 Share Posted November 2, 2009 I've corrupted my A&D Material Library in the past - it must be very sensitive. I've since switched (recently) to creating my own Material Libraries and have used a script on here to browse to a folder and it loads the MatLibs for you. Makes it easier. Here's my fix for the missing slots: A&D Materials Disappear: Close Max Find this file: mrArch_DesignTemplates.mat rename it to something else (mrArch_DesignTemplates-BAD.mat) Find a GOOD COPY of this somewhere (I copied mine from the 32-bit version of 3DS Max) Copy in the same folder as where the original was found and renamed re-start max If that fixes it, right click on the file and make it READ ONLY. That way, it cannot get overwritten any more. Link to comment Share on other sites More sharing options...
pixelperfectg Posted November 2, 2009 Share Posted November 2, 2009 In case you don't have a backup copy of the file, I put on here: http://forums.cgsociety.org/showpost.php?p=2921693&postcount=2 in tip #24 Link to comment Share on other sites More sharing options...
SandmanNinja Posted November 2, 2009 Share Posted November 2, 2009 Thanks Jeff - you are Legendary! I'm thinking of starting to use this plug-in/script: http://matmanager.110mb.com/Index.html Ten Europe-Dollars - a pretty great bargin for what it does. No more corrupt A&D MatLibs and the things are stored logically. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted November 2, 2009 Share Posted November 2, 2009 As both a side note, and a general working note, I always duplicate my Max directory as soon as a new copy is installed. I am bound to mess something up at some point, and it is a good way to have a original of any file you may corrupt. "3dsMax Design 2010" "3dsMax Design 2020 - Original" Link to comment Share on other sites More sharing options...
