Fillet on a solid
Cesar R
hello , what command is used to set that number of faces the composed a fillet on a 3D solid.. is there something similar to surftab1 / 2?
thank you, :)
another problem i ran into... how can I make a revsurf'ed ofject so the the normal face outward. IE shaft of a column.
[ December 24, 2002, 09:05 PM: Message edited by: Cesar R ]
Hi Cesar,
Why u need it? Send me an example. There r some useful varibles u can use with solids but I need more info... If I can't purge layer it's simply "blocked" by objects, IE: blocks, dimension tags, etc. Send an example. I can help u if I can define your problem. Best regards.
