rpict Posted February 10, 2004 Share Posted February 10, 2004 does anybody know about a lisp routine, that puts entities with a particular color on a particular layer? e.g. all entities with color yellow on layer 0 are put on layer wall, all entities with color white on layer 0 are put on layer windows etc. all that should go in one run at once. -rpict Link to comment Share on other sites More sharing options...
mtutaj Posted February 10, 2004 Share Posted February 10, 2004 what version of Acad, and how many drawings do you have to convert? if it is only a couple, I would just filter the selections out. I just relized that Multi-batch has that routine already built into it.. its called "Change Items of a color to a layer" www.multi-batch.com if your someone like me who doesn't have the time or all the skills to program yet. Hope that helps, Mike Link to comment Share on other sites More sharing options...
rpict Posted February 10, 2004 Author Share Posted February 10, 2004 thanks mike that's the thing i was after. i used to filter them out in the past, but with a dozen colors its getting boring. -rpict Link to comment Share on other sites More sharing options...
kobuzz Posted February 10, 2005 Share Posted February 10, 2005 Hi there, I tried the Multi-batch, and allthough I will keep it 'cause of the many functions, it does not work for the color to layer in my case. I use AutoCAD 2000LT and the function is not selectable then. Does anyone know of a separate LISP that I can use? I have about 2700 .dwgs (Bolt & Nut library) I need to convert. Multi-batching would be the best, but I would gladly settle for a LISP per drawing, which still saves me a lot of time. -kobuzz Link to comment Share on other sites More sharing options...
mmangold Posted February 10, 2005 Share Posted February 10, 2005 I created a simple lisp for you. If you are using LT I don't think you can run lisp files unless you have an addon. If you have any problems let me know Mike (defun c:colortolayer () (setq orgcolor (ssget "x" '((62 . 1))));; . 1 is the color (command "change" orgcolor "" "p" "la" "lay1" "");; place layer name here where lay1 is (setq orgcolor (ssget "x" '((62 . 2))));; . 2 is the color (command "change" orgcolor "" "p" "la" "lay2" "");; place layer name here where lay2 is (setq orgcolor (ssget "x" '((62 . 3))));; . 3 is the color (command "change" orgcolor "" "p" "la" "lay3" "");; place layer name here where lay3 is (setq orgcolor (ssget "x" '((62 . 4))));; . 4 is the color (command "change" orgcolor "" "p" "la" "lay4" "");; place layer name here where lay4 is (setq orgcolor (ssget "x" '((62 . 5))));; . 5 is the color (command "change" orgcolor "" "p" "la" "lay5" "");; place layer name here where lay5 is (setq orgcolor (ssget "x" '((62 . 6))));; . 6 is the color (command "change" orgcolor "" "p" "la" "lay6" "");; place layer name here where lay6 is (setq orgcolor (ssget "x" '((62 . 7))));; . 7 is the color (command "change" orgcolor "" "p" "la" "lay7" "");; place layer name here where lay7 is (setq orgcolor (ssget "x" '((62 . 8))));; . 8 is the color (command "change" orgcolor "" "p" "la" "lay8" "");; place layer name here where lay8 is (princ) ) Link to comment Share on other sites More sharing options...
Fernando Lino Posted February 15, 2005 Share Posted February 15, 2005 You can also select entities by color and move them by hand...of course, it's not automatic but it works fine Link to comment Share on other sites More sharing options...
kobuzz Posted February 21, 2005 Share Posted February 21, 2005 Thank you both for your help. I have not had the time ot check the LISP, I simply cannot find the time here at work. I will see if I can try it at home. Thankx again. Jacob Link to comment Share on other sites More sharing options...
