Glass looks 'tinted' viewed from inside
Geoffc
I'm working on an interior render, using a beach shot as the background map. I'm using standard vray fresnel glass. But as you can see, where the doors are open, the background looks correct, but the glass material causes the doors and windows to look fairly tinted. I've messed with quite a few settings (fresnel on/off), IOR, diffuse/reflection/refraction colors, etc, but I can't seem to shake the 'tint'. I must admit I'm no specialist with materials at all either.
Suggestions? Thx!
So after trying everything, I inadvertently found the solution: vray cam exposure! I'm using a vray sun & cam, and photometrics on the interior. Iwas adjusting the cam exposure for something else, and noticed the glass get a lighter 'tint'. Doing other tests, this was not due to the interior lights or vraysun. So, I adjusted my vraycam exposure until the glass looked good, then adjusted my lighting to match. Looks good so far!
I agree, it looks much better all around! I am slightly confused by the light levels though - I can't tell what the weather is meant to be outside. It doesn't look too sunny, and if it were then then the windows would probably be bleached out quite a lot. But at the same time, the sky and sea looks quite blue.
Dan, so far I've purposely 'cheated' the exterior light levels by lowering the sun intensity quite a bit. The render ends up looking much like either an HDR photo, or multiple photos stitched together. You are correct, a single shot on a sunny day from inside would really create blown out exterior exposures.
Reason I did so, is this is being used by a realtor to sell a high end beach house, and prospective buyers would never recognize the irregularity, but will notice the beautiful outside environment.
Roger Dodger! Gotta give 'em what they want!
