Menno Posted February 26, 2004 Share Posted February 26, 2004 Hey, I've made a 3d Model, and now I want to generate a section. I'm using the standard section stuff (just like elevation) to produce them. But they look extremely bad. Every vertex is located at a 1mm interval. For instance, every cornerpoint of a hole in a beam is located at a multiple of 1 while they're not supposed to. Everything of thickness 1.2mm becomes 1 mm, etc. And my aluminium cladding panels, which are round at the bottom, become square. And yes, they too at 1mm intervalls. Would the "section" command be a better procedure for producing my cut throughs (2d)? Elevation is the same story, it doesn't produce the output I need. BTW, sections of a tube produces all the edges, but when I turn dispsilh to 1, it vanishes, along with the outermost edge.... any solution to this problem? (I don't want all the inner lines, but do want the outlines). Link to comment Share on other sites More sharing options...
