gfriedman Posted November 13, 2009 Share Posted November 13, 2009 I need to downsave to a different version of max, but I need to preserve my vray physcam positioning so I can overlay a different style rendering overtop another one - is there a way to convert a physcam to a standard one - so I can export as fbx or is there a script out there for exchanging physcams between versions? since not alot changes re:cam's basic settings it seems like it should be fairly easy to export and import...but I can't figure it out anyone have any ideas? Link to comment Share on other sites More sharing options...
alias_marks Posted November 13, 2009 Share Posted November 13, 2009 This would be kind of a funky work around, but might work if you need the vrayphys camera to be exact. 1. View physcam 2. convert to perspective (shortcut P) 3. Ctrl + C to create a native max camera 4. Export fbx 5. Import fbx and view standard camera in viewport. 6. Use the script 'Anything to Physcam' from lele's vray scripts 7. You'll have to re-apply camera settings but this should at least get you the same exact location and view for a vray phys cam. Probably an easier way, but this would be my approach, good luck Link to comment Share on other sites More sharing options...
gfriedman Posted November 13, 2009 Author Share Posted November 13, 2009 Thank You!!! Link to comment Share on other sites More sharing options...
alias_marks Posted November 13, 2009 Share Posted November 13, 2009 you're welcome, did it work? Link to comment Share on other sites More sharing options...
gfriedman Posted November 16, 2009 Author Share Posted November 16, 2009 interestingly, I didn't even need to convert to normal cam - the vray cams appeared in the downsaved fbx... thanks! Link to comment Share on other sites More sharing options...
alias_marks Posted November 16, 2009 Share Posted November 16, 2009 ah, very cool. good to hear vray and fbx are playing nice... Link to comment Share on other sites More sharing options...
