Mysteroius Black Shape in Reflections....
Guest mutkakokudka
Guest mutkakokudka
Hello everybody,
I ' ve encountered a strange "bug" i think with vray & 3d Max....i am using vray Sun/Sky & physical cam. Suddenly at the glass surfaces i have a black shape that come across over the part of the glass....of course there is nothing behind. Reflection map is the same Vray Sky, i have the sun set invisible. I tried to turn off Vray Sky and put different environment but no result so i guess it's not the enivronment. I also acreated a new geometry (a simple plane) and i put a different reflective material but the strange circle is still there.
I thought maybe someone here could have encountered similar problem.....
Any help is highly appreciated
Thanks
Guest mutkakokudka
Thank you for the answers.
I found that the problem is that i am using falloff reflections (perpendicular to viewing direction), once i switch to Fresnel is ok.
The IOR is 1.517, i tried 1.6 also, it is a glass with thickness ...do you guys know how can i prevent this with falloff (i use it often because i can control better "fresnel" effect)
I will try to lower cut off settings and i will let you know
thanks
