erickdt Posted November 19, 2009 Share Posted November 19, 2009 Hello all, I am trying to create a book in MAX that is rigged for animation. To that end I have created my page from two standard boxes that I converted into editable polys, one for the base of the page which will bend 180 degrees + and one for the rest of the page which will bend more gently as the page turns. I've set this all up with the two bend modifiers etc. now the only issue is that when I use the bend modifier that controls the tight bend at the base of the page it elongates the rest of the object. Any ideas of how to fix this? Thanks in advance. E Link to comment Share on other sites More sharing options...
davistalexander Posted November 19, 2009 Share Posted November 19, 2009 check out bookrigger @ scriptspot.com. that should do what you are looking for. Davis:D Link to comment Share on other sites More sharing options...
dannydesil Posted November 26, 2009 Share Posted November 26, 2009 please tell me how can i change pivot point after applying bend modifier to a box? after i apply bend modifier, i need to bend it again to the same side. but pivot point must be changed to the top of the object. hope you understand. sorry for my bad English. Thanks Link to comment Share on other sites More sharing options...
