programming an intellimouse in autocad
brg
brg,
It all depends in what version of AutoCAD you are using. I can recall having this same problem under AutoCAD 14. But anyway, I think you should try the following:
Download and install the latest IM software at:
www.microsoft.com/hardware/mouse/download.asp
Go to Control panel then Mouse. In "Mouse property" window under the "Buttons" tab go to settings. There you would be able to add your software, (in this case AutoCAD) and then costumize the buttons for it. AutoCAD should pick up the new settings.
In AutoCAD go to options, then under the "preferences" tab make sure you have checked the box "windows standard accelerator keys".
