aristocratic3d Posted November 20, 2009 Share Posted November 20, 2009 (edited) HI, I have found my few files in different system unit setup. I dont know what system unit setup should I use for vray. Can any body help me? thanks Edited November 20, 2009 by aristocratic3d Link to comment Share on other sites More sharing options...
Thablanch Posted November 20, 2009 Share Posted November 20, 2009 Never had a unit setup issue with Vray. It works ok with anything, metric or imperial, no problem. Link to comment Share on other sites More sharing options...
BrianKitts Posted November 21, 2009 Share Posted November 21, 2009 No one unit setup is better than the other as long as you work with real world sized (regardless of unit type) elements. It's when you start building things in unrealistic sizing that you will be throwing off things like your mapping and IES lights. Link to comment Share on other sites More sharing options...
aristocratic3d Posted November 21, 2009 Author Share Posted November 21, 2009 I believe it, but it depends on display unit setup. if my display unit setup is feet. I can create a table two and half feet high in the system unit setup of centimeter. BUT WHEN I CHANGE THE SYSTEM UNIT SETUP TO INCHES THEN THAT TABLE DISPLAYS A HEIGHT OF 6.35 FEET. DO YOU WANT TO SAY THAT THE HEIGHT OF THE TABLE IN BOTH SYSTEM UNIT SETUP IS SAME. I HOPE NOT. DO YOU WANT TO SAY THAT, TWO TABLE RECEIVE EQUAL LIGHT WHEN THEY HAVE A DIFFERENT MEASUREMENT. Thanks Link to comment Share on other sites More sharing options...
kippu Posted November 21, 2009 Share Posted November 21, 2009 actually IES lights depends on system units but the rest of the lighting is not dependent on the units , you can experiment for yourself and check it Link to comment Share on other sites More sharing options...
Thablanch Posted November 22, 2009 Share Posted November 22, 2009 BUT WHEN I CHANGE THE SYSTEM UNIT SETUP TO INCHES THEN THAT TABLE DISPLAYS A HEIGHT OF 6.35 FEET. You are telling Max what the units are in. So, you must set units before drawing stuff. If you set your units to feet, but import a table made in cm, it will convert it, cause the file has a unit proprety. You did draw something 6.35 units, you just have to decide what the units are. Link to comment Share on other sites More sharing options...
zhopudey Posted November 23, 2009 Share Posted November 23, 2009 If you are going to import models/plans from another program, then set the system unit to whatever you used in that program. Never change the system unit after bringing any models into the scene. The display unit doesn't matter. You can change it whenever you want. Regarding your table: 1" = 2.54cm, so when you changed the system unit, the table got scaled by 2.54 times. Hence the resulting length of 6.35 feet. Link to comment Share on other sites More sharing options...
