VRay Object ID Coming Out with Serious Aliasing
erickdt
Any ideas??? This is driving me up the wall. I cannot for the life of me understand why anybody would ever even want a non-filtered object ID pass. Why this is one of the only render elements that doesn't have filtering automatically checked is an absolute mystery to me...
I suppose it could be for the same reason that it's a bad idea to have AA on a z-depth pass that you're using to drive a depth blur - that anti-aliasing essentially gives an "impure" colour. That is, in the case of a z-depth, a black object in front of a white one will end up with a slightly grey border after anti-aliasing, which mucks with the depth blur, as now there's an area of the image that's "between" the black and the white. I suppose the similar is true of colour ID's. Given it's purely a 2D process, you can't have AA turned on, or else the edge of a blue object over the top of a yellow one will give you a slightly green border, which of course wouldn't correspond to either objects in a comp.
Well, that makes sense to a point but you can easily account for that sort of issue by adjusting your magic wand/color range tolerance within Photoshop. If you're using an object ID pass as the basis for isolating objects in Photoshop a heavily aliased object ID pass doesn't do you much good. No?
Anyway... Does anyone have any suggestion as to what's going on here and how I can fix it?
I agree, it's a pain. I don't know the solution, though - after all, the pixels created as a result of the anti-aliasing could well end up being the same colour (or nearabouts) as another object id colour. Personally what I do is split the image up into a number of images which each only have 3 object IDs, one at 100% blue, one at 100% green and one at 100% red. This minimises the issue as it's very unlikely that any anti-aliasing you do will affect another object in the scene. This requires, I suspect, manual rendering rather than as a simple pass but I know a lot of people in the VFX industry who do it this way - though this may be because, at the time, their colour-picking tools were not quite as developed as Photoshops.
The thing that is the most wierd about this is that this issue appears to be specific only to this file/geometry (it also happens when I merge my scene into a new scene). I did the pulti-pass method on several renderings this past week with filtering enabled and it worked beautifully. I cannot for the life of me understand why it's not working now.
E
So... you can strike my last post. I just opened the object ID pass from the other file that I was saying was anti-aliased and saw that it was in fact just as aliased as this new one it only seemed smoother becasue the resolution was much higher. So there you go: there is no way to properly anti-alias the object ID pass from VRay. To any Chaos group folks that might be listening: please fix this issue.
E
Not sure why you didn't just go to chaos group's forum with this, it's a known issue that's been discussed many times before.
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=32211&highlight=antialias+render+elements
Basic explanation is that the render ID's are expressed in integer values not floating point so they can not be filtered. However some of the other render elements are so they now have the option to be filtered. Basically Chaos has done what they can with the data that max creates, but can't do more.
You'd be better to direct your request @ Autodesk, not chaosgroup.
I didn't post it in the chaos group forums because I'm not (yet) a member there.
I'll let Autodesk know about my issue although I'm sure they've heard it before. What would be the best avenue for letting Autodesk know? A forum? Tech support?
E
So to make more than 3 masks you need to enable more than one instance of VRay MultiMatte within render elements and change the gbufID values to the corresponding object ID values that you want masks for. So if you need to mask out 6 things you enable multimatte twice in render elements, three times for 9 and so on.
Not a perfect solution but better. This feature of VRay makes me think that they could do the same thing with unlimited ammounts of colors (for masks). That would certainly be a helpful tool. I'll suggest this over in the Chaos Group Forums.
Thanks for everyone's help!
E
no no no!
The point of using a multi-matte element is so you can use the channels box in photoshop!
Using select colour range and refine edge will never give you a perfect selection.
Have your multimatte layer selected, go to you channels pallette and ctl+click one of the red green or blue channels and it will load the selection perfectly.
no no no!
Yeah sorry, I was referring to the Object ID pass rather than multimatte.
  • 3 weeks later...
