Problem again with the v-ray light
aristocratic3d
Hi,
I have been facing trouble with the darkness behind the v-ray light. Even I cant avoid that darkness. pls let me know what to do to get a nice illumination into the room. If I increase the intensity room become bright. But darkness behind the light and also a glowing appeared surround the light.
I am not that expert in v-ray and not also in English. pls allow me.
Thanks in advance.
Edited by aristocratic3d
If you must use a big light like that, then place it outside the room, and exclude the front wall from it. If all the walls are a single object, you'll need to detach the front wall.
However, it is better to place the light only in the doorway, like Tommy suggested. Or else use vray sun + vray sky.
