2.5 Snap suddenly not behaving as expected
MegaPixel
I may very well have toggled something I'm unaware of that is causing this, but I've noticed lately that my 2.5 Snap is not behaving as it used to. I like to use my Ortho views to make adjustments to vertices by 2.5 snapping to other reference objects (which may be at different Z distances) to move them. Normally, this movement would be restricted to X or Y but lately my verts have been snapping to the Z, onto the objects I'm snapping to - Incredibly annoying. Could someone please be my Hero and give me a perfectly logical explanation for my issue that makes me go "Well Duh!" Thank you - Dave
Using: 3DS Max 2009 Design 64bit - SP1 on WinXP64
Its a bug I have come across. If you switch the toggle to 3 then snap on something and switch it back to 2.5 . It fixes it. I normal don't use 3 that much so I set up the 2.5 in my maxstart file. If you look at it through maxscript when it is happening you will see the toggle is not showing what it is set to in max.
