jackb602 Posted November 22, 2003 Share Posted November 22, 2003 I've been using AutoCad for longer than I care to remember, and I've never seen this problem before. I'm trying to XREF a sheet border into a file in Layout space. I can XREF the file and attach it, but it's nowhere to be found in the drawing. I've been experimenting for a while and this problem is somewhat intermittent. Has anyone ever run in to this problem before? Any ideas? I'm running Autocad 2002 on Windows 2000. Thanks, Jack Link to comment Share on other sites More sharing options...
Kerry Thompson Posted November 22, 2003 Share Posted November 22, 2003 Hi jack602 Just check that the title sheet is not in layout space on the xref file - only entities in model space are xrefed. Also check that the insertion layer of the xref is not frozen. Cheers Kerry Thompson Link to comment Share on other sites More sharing options...
Kerry Thompson Posted November 23, 2003 Share Posted November 23, 2003 Not a problem. Cheers Kerry Link to comment Share on other sites More sharing options...
jackb602 Posted November 23, 2003 Author Share Posted November 23, 2003 D'oh! Thanks Kerry, that was exactly the problem. I'm setting up my own title block for the first time, and I of course drew everything in Layout space. Pasting it into model space did the trick. Thanks for your help! Jack Link to comment Share on other sites More sharing options...
Guest IG Oliver Posted September 26, 2006 Share Posted September 26, 2006 jackb602 said: I've been using AutoCad for longer than I care to remember, and I've never seen this problem before. I'm trying to XREF a sheet border into a file in Layout space. I can XREF the file and attach it, but it's nowhere to be found in the drawing. I've been experimenting for a while and this problem is somewhat intermittent. Has anyone ever run in to this problem before? Any ideas? I'm running Autocad 2002 on Windows 2000. Thanks, Jack Try detach-purge then attach again.. Link to comment Share on other sites More sharing options...
