RevitGary Posted November 24, 2009 Share Posted November 24, 2009 Is it possible to exclude an object from the sun? I see with a regular light you can exclude an object from receiving the light. I also see in object properties you can exclude GI and final gather. I dont see an option for excluding an object from receiving sun light in the sunlight parameters. Is there a way to do this? I have back ground images I that I do not want to be effected by the sun light. Link to comment Share on other sites More sharing options...
mattclinch Posted November 24, 2009 Share Posted November 24, 2009 (edited) i think you have do break the daylight assembly apart and then you can add an exclude list to the mrSun.... not sure on that though. EDIT - nope, doesn't work. not sure if this is possible with mrSun. Edited November 24, 2009 by mattclinch Link to comment Share on other sites More sharing options...
thnkr Posted November 24, 2009 Share Posted November 24, 2009 Wouldn't it make more sense to give the bg plates a material that does not respond to illumination, such as a surface shader? It would make things a whole lot simpler. Link to comment Share on other sites More sharing options...
